I had to update to win10 and installed VS2015 again to build the cyusb3 drivers from the sources that are provided in the CYUSB3_USB_Suite_Source.zip file.
As far as I can tell I have everything updated, SDK and WDK as required in readme file.
When I open the project file file cyusb3_win10.sln I get a weird error.
C:\test\VS2015\CyUSB3_Source\src\cyusb3_win10.vcxproj : error : Unable to read the project file "cyusb3_win10.vcxproj".
C:\test\VS2015\CyUSB3_Source\src\cyusb3_win10.vcxproj(39,5): The imported project "C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V140\WDKConversion\PreConfiguration.props" was not found. Confirm that the path in the <Import> declaration is correct, and that the file exists on disk.
This file does not exist and the "WDKConversion" subfolder is empty.
What additional souces/tools do I need to install to compile the dirver succesfully?
You can download and install the WDK for VS 2109 from this link https://docs.microsoft.com/en-us/windows-hardware/drivers/download-the-wdk
Download the Windows Driver Kit (WDK) - Windows drivers | Microsoft Docs
Yatheesh
