I can't find a dev board for the FX3S (with SD support). The only mention is some board from a partner (Pactron) whose website seems to be not functioning. Is there anywhere else they can be purchased?
AshwinN_21
10 sign-ins 5 sign-ins First solution authored
Please send your request for buying FX3S DVK / FX3S RAID-on-Chip USB Dongle to the following email addresses:
  1.   Arvind_kumar@pactroninc.com
  2.   brian_koo@pactroninc.com
There seems to be issues with support@pactronstore.com and also the pactron store web site is not accessible. Please direct your queries to the above email addresses.
annr
Can you please try E-mailing them?
Email:
gerard_connolly@pactroninc.com
support@pactronic.com
Hello, thanks for your response.
I tried emailing both addresses you supplied but both of them bounced back with an undeliverable error.
Any further suggestions?
We will contact pactronic and update you on this ASAP.
- Madhu Sudhan
I face the same problem.
Is there any update about this case?
The E-mail ID is support@pactronstore.com (Please ignore the previous E-mail IDs).
Pactron has now changed the procedure to order. Customers need to contact this E-mail ID and mention their requirement.
-Madhu Sudhan
Thank you for the e-mail address!
I will try to contact them though this address.
I sent e-mail to them and I still have not received any message.
Do you have their phone #?
I sent a message to the Japanese staff of Pactron and got a response.
Thank you for your support.
Hi, could you provide the contact details that worked for you please.
Anyone any ideas on this?
-Madhu Sudhan
I sent an email to the address given and just received this response.
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed:
    (ultimately generated from support@pactronstore.com)
    Domain pactronstore.com has an outgoing mail suspension.  Message discarded.
  ghuru_K@pactroninc.com
AshwinN_21
annr
