grov_3935901
I'm using Eclipse under MacOS and trying to build the Chapter4Example1 project from SuperSpeed Device Design by Example.
When I build the project, Eclipse gives me this error:
Eclipse is looking for "cs-make" in the yagarto-4.7.2/bin directory, but there is no cs-make there:
What make utility should be used for Eclipse under MacOS and how do I configure the environment to point to it?
YangyangC_06
Hi Gregory,
Sorry for the confusion. Yes, you are right. Cs-make(measn GNU cross make) is the tool we use in Windows platform.
In Linux and IOS platform it should be make instead of cs-make.
The error comes since you are trying to build the project from Windows in IOS. Please try to change cs-make to make and build it again.
YangyangC_06
Hi Gregory,
