ElTa_4521156
Level 4
Level 4
100 sign-ins 50 replies posted 50 sign-ins
Is there any example for multiple thread in GPIF for sending continuous data from USB to GPIF to help me on my project , just like "reversing" the configuration in AN75779?
data is lost every 16KB in my project. Based on AN75779 documents, I should do multi threding in GPIF. In AN75779, data goes from GPIF to USB, but I have problem from USB to GPIF.
Rashi_Vatsa
In the firmware you shared in this thread Multiple Thread in GPIF II for DR_data , i found that the configuration for serial out is  0x00001F83,  /*  CY_U3P_PIB_GPIF_SERIAL_OUT_CONFIG */
which is socket zero ( as mentioned in GPIF_SEROUT_THREAD_NUMBER_MASK (bit 3:2) is configured for data sink (from USB to GPIF).
As you are using two sockets (thread) in you firmware, this field should be 0. So that the socket is chosen internally (as per the thread)
So the configuration should be 0x00001F81,  /*  CY_U3P_PIB_GPIF_SERIAL_OUT_CONFIG */
I have tested this at my end. Refer to the results
PS: I have changed the DMA buffer size and endpoint size to 1024 (for testing purpose)
Rashi
Rashi
JayakrishnaT_76
Is this a duplicate thread of a thread created before. The thread created before is mentioned in the following link.
If so, Please carry on the discussion in the previous thread.
Jayakrishna
Jayakrishna
Rashi_Vatsa
Rashi
Rashi
it was the exact answer. It works now.
Thanks alot.
