Hello.
The driver resell work you worked on went well. Thank you.
However, the upload to the Microsoft hardware dashboard failed after working with the document.
I am attaching the revised package and error log. Please advise me what is wrong.
Hi Huton,
Kindly refer to the Part III-Driver Resell from the attached document and open the HLK studio as driver update.
Meghavi
Hi Huton,
Can you please let me know in which step you are getting this error? Are you getting this error while submitting the driver on the dashboard for certification?
Meghavi
HI
I followed the instructions in the document. And I registered, but I failed Microsoft hardware dashboard certification.
This error log is a missing file error in the Microsoft Dashboard.
If the driver is called HLK Stodio again after updating the driver, will 4 be created in the driver folder, is it OK?
Regards.
After replacing the driver with a modified inf file, you would need to create a package and upload the EV certificate. Once the package is signed, you can upload it to the Microsoft Dashboard for certification.
Meghavi
