MIPI DATA TYPE
yaqi_4776616
Level 4
Level 4
50 sign-ins 25 replies posted 25 sign-ins
Hi
Does anyone know more about MIPI data?
Here is the mipi data signal from the sensor I detected with an oscilloscope 
I found that the correct MIPI Data signal should be as shown in the lower part of the picture above, the reason my signal is not correct is that the platform terminal is not in effect, I would like to know what this means, thank you very much for your help.
Yaqi
Hemanth
First like given First question asked 750 replies posted
Hi Yaqi,
Can you please specify which part of the waveform you think is not correct in your scope capture?
I think low power to high speed transition is happening in your waveform too.
Hemanth
yaqi_4776616
Level 4
Level 4
Hi Hemanth
This is the correct MIPI signal
The normal MIPI signal will have a voltage change at this position below
And here's my signal
And my signal is such that there is no voltage change. The explanation of the cause of this says that the terminal is not connected, I do not know what this means
Yaqi
YiZ_31
May I know what have you done in CX3 side? Have you set the correct sensor configuration in firmware and initialize mipi block?
Eddie
