hi when i try to debug use jtag to debug cyusb3014 it occur "error while launching command:gdb --version"
attached file is my configuration, the last one is error window and informations of open gdb server manually
Please follow the instruction in section 3 of attached document. Make sure you terminate all the existing debug session before you start a fresh.
Please check the video link as well: https://cycorp-my.sharepoint.com/personal/nisa_cypress_com/_layouts/15/guestaccess.aspx?guestaccesst...
sorry cant open your video links
i sure i followed user guide step by step and no another debug session opened, all attached images can prove it
i think it may the windows environment or somehing like that problem?
Please try the following link:
Right click and open in a new tab
