Here is the thing that I 've bought an CYUSB3KIT-003,and I used it in slave fifo mode. I used FLAGA and set it to gpio_21. As I understand it, gpio_21 is connected to the CTL_4 pin of the board so it should be logic 0 after the board is booted, however , its voltage was about 0.9V.
How is it happen?
As FX3 is used in slave mode, PCLK is expected. Check CTL4 with PCLK in place. Let us know if any further queries.
AliAsgar
When I was measuring the vlotage of the CTL4, the PCLK is not connected. So it does matter, right? The CTL4 will get weird if there is no PCLK input?
Thanks so much.
AliAsgar
Hi AliAsgar,
The FX3 works fine after I attached PCLK to it!
Thanks so much!
