I am using SDK V1.2 and I can not create a Multi Channel DMA with a size of 1024 and a count of 16. Is it possible to do this with the latest SDK?
Yes. It is possible.
You should not be seeing any issue if you are trying to create a channel with size 1024Bytes and count as 16.
Please attach your code here. I will take a look at it.
sai krishna.
