Industry-first USB 10Gbps device controller. Check it out now!
MeSr_4460526
Can someone confirm if hardware strapping is required for JTAG pins?
In datasheet it is mentioned that JTAG TDI, TMC, and TRST# signal has fixed 50k internal pull-up resistor and TCK has fixed 10k pulldown resistor
Menaka
Hello Menaka,
I can confirm that CX3 doesn't need any external hardware strapping on the JTAG pins.
As mentioned in the datasheet, the JTAG pins: TDI, TMC, and TRST# signal has fixed 50k internal pull-up resistor and TCK has fixed 10k pulldown resistor.
Yashwant
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi MeSr_4460526​,
Can you please let us know which device you are using?
For designing the schematic of your custom board you can refer to your respective device's hardware design considerations document.
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Hi Rakshith,
Thanks for the reply!
I am using CX3 in my design, can you please confirm if any hardware strapping is required for the JTAG pins of CX3/FX3?
Menaka
Hello Menaka,
Yashwant
Hi Yashwant,
Thank you for the reply!
Menaka
