nich_4171101
First like received
Hi Kandla,
I've already changed the sensor ID based on the MT9v034 in sensor.c, by using UART log still showing Reading sensor ID failed!
Please advise
According to datasheet MT9V034 sensor id is  0x1324
The 0x00, 0x00 is actually what address ?
Thanks & Regards,
Nigel
Reading sensor ID issue is solved by setting proper I2C Configuration as per the sensor requirement.
KandlaguntaR_36
25 solutions authored 10 solutions authored 5 solutions authored
Nigel,
The 0x00, 0x00 is the memory location that we are tryting to read - considering that Sensor ID is located in 0x0000 address.
Please refer the source code of SensorRead2B.
In the default AN75779 firmware, the sensor ID is located at 0x00, 0x00 location.
Can you please print the buf[2] here and check whether it is matching the Sensor ID?
HI Sridhar,
May i know where should i print  buf[2], is it in the sensor.c file------>from the funtion of SensorI2cBusTest  ??
Rgds
Nigel
You can print in sensor.c file in I2CBusTest function itself.
Sridhar
Hi Sridhar,
Can i used the way below to print out the buf[0] and buf[1]  ??
uint8_t SensorI2cBusTest(void) {
/* The sensor ID register can be read here to verify sensor connectivity. */
uint8_t buf[2];
/* Reading sensor ID */
     if (SensorRead2B(SENSOR_ADDR_RD, 0x00, 0x00, buf) == CY_U3P_SUCCESS) {
          CyU3PDebugPrint("%d", buf[0]);
          CyU3PDebugPrint("%d", buf[1]);
     return 1;
Rgds
Nigel
Add priority value to this API CyU3PDebugPrint(4, "%d", buf[0]); CyU3PDebugPrint(4, "%d", buf[1]);
Hi Sridhar,
This is how i wrote the program to print =======>uint8_t buf[2];
        SensorRead2B (SENSOR_ADDR_RD, 0x00, 0x00, buf);
On the uart log it shows this :
Entering USB Suspend Mod 00UsbEventCB: Detected SS USB Connection
USBSetupCB:In SET_FTR 0::1
UsbEventCB: SUSPEND encountered...
Can you please do this?
uint8_t
SensorI2cBusTest (
        void)
    uint8_t buf[2];
     CyU3PDebugPrint(4, "I am in bus test \r\n");
    if (SensorRead2B (SENSOR_ADDR_RD, 0x00, 0x00, buf) == CY_U3P_SUCCESS)
        CyU3PDebugPrint(4, "%d\n\r", buf[0]);
        CyU3PDebugPrint(4, "%d\n\r", buf[1]);
        if ((buf[0] == 0x24) && (buf[1] == 0x81))
            return CY_U3P_SUCCESS;
     else
               CyU3PDebugPrint(4, "Reading 0x0000 location of sesnor is failing \r\n");
    return 1;
Please use the Debugprints in your firmware except in callback functions and find where it is going wrong.
In your last response, there is no debug print related to Sensor ID if the SensorRead2B  is success you should see the buf 0 and buf 1 values.
You may use JTAG debugger as well. If you are using SuperSpeed Explorers kit, you can also integradted OpenOCD debugger as well.
Please refer UserGuide provided in documentation folder of the SDK: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\firmware
Hi Sridhar,
I have tested the code that you shared. It seems like the sensor id is not store at 0x0000 address.
I am in bus test
Error: Reading Sensor ID failed!
Entering USB Sus
Rgds
Nigel
Nigel,
As per the logs, SensorRead2B is failing.
Add the following in SensorRead2B function.
apiRetStatus = CyU3PI2cReceiveBytes (&preamble, buf, 2, 0);
    CyU3PDebugPrint (4, "I2C Read Statue = %x\n\r", apiRetStatus);
Please probe the I2C lines and understand what is happening over I2C (whether there is ACK from the I2C device).
Please confirm whether the i2c slave device address is correct.
Hi Sridhar,
according to the mt9v034 image sensor data sheet the i2c slave addresss is 0x91 its correct.
Hi Sridhar,
I probed to the sckl but its seems the signal its just flat 3.4v. I'm using the AN75779 firmware change the i2c slave address according to the MT9v034.WhatsApp Image 2019-07-15 at 4.44.06 PM.jpeg
Rgds
Nigel
Can you please use the I2c example firmware on explorer kit and check whether there is any activity on I2C lines?
SDK path: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\serialif_examples\cyfxusbi2cdmamode
Hi Sridhar,
Yes i have tested:
The i2c lines just at 3.4v
Rgds
Nigel
Please let me know your testing procedure.
Sridhar
Hi Sridhar,
Procedure:
  1. Imported  the code from C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\serialif_examples\cyfxusbi2cdmamode  to EZusbsuite
  2. In Ezusbsuite: Click Project-> Build all  then debug folder created.
  3. The PMODE J4 is open  short when load the code into  i2c EEPROM.
  4. Used control center to load the UsbI2cDmaMode.img which is created in the Debug folder, the UsbI2cDmaMode.img is loaded into the I2C EEPROM
Rgds
Nigel
Nigel,
  3. Place the Jumper J4 so that the device will enumerate as Cypress USB bootloader device
  4. Read the Readme.txt
  5. Open Control Center, select Control Endpoint of Bootloader device
  6. Send the Vendor Command as said in Readme.txt
  7. Probe the I2C lines while sending the Vendor command
Hi Sridhar,
I just checked on the register reference of mt9m114, the sensor id is store at R0x0000 value= 0x2481 which is same as the one in an75779pastedImage_0.png
For Mt9v034 the register reference shows the sensor id is store at R0x00 value=0x1324. Its only 8bit address instead of 16 bit.
Its only 8bit address instead of 16 bit. So need to change this potion to 8 bit.
May i know if i want to change the preamble.buffer[?], which do i need to change ?
Rgds
Nigel
Nigel,
Reduce the Premable length to 3 and pass only one byte address.
Sridhar
Hi Sridhar,
In the meantime, i will design the hardware for mt9v034 and fx-3.
  1. Do we need the ext SRAM because FX-3 already have embedded SRAM ?
  2. To store the firmware we need an EEPROM, if i follow the one in Eva board is that advisable?
Please kindly advise
Nigel,
Have you test the below?
Note that this needs to be done only when you are reading Sensor ID:
preamble.buffer[0] = slaveAddr & I2C_SLAVEADDR_MASK;        /*  Mask out the transfer type bit. */
    preamble.buffer[1] = lowAddr;
    preamble.buffer[2] = slaveAddr;
    preamble.length    = 3;
    preamble.ctrlMask  = 0x0003;                                /*  Send start bit after secondbyte of preamble. */
>>   Yes. You do not need it. The SRAM which is externally placed on CYUSB3KIT-003 is for demonstration of ASYNC SRAM functionality.
>> Yes, you can use the one used on Eva board. You may also use SPI Flash as well. Please refer AN76405
Nigel,
Please create a new thread for a new query.
Sridhar
Hi Sridhar,
Yes i have tested. But the sensor id read from I2c  still doesn't match the one in datasheet.
I'm using the following code:
CyU3PReturnStatus_t SensorRead2B(uint8_t slaveAddr, uint8_t lowAddr, uint8_t *buf)
  CyU3PReturnStatus_t apiRetStatus = CY_U3P_SUCCESS;
  CyU3PI2cPreamble_t preamble;
  if ((slaveAddr != (uint8_t)0x91) && (slaveAddr != (uint8_t)0xA1))
          CyU3PDebugPrint (4, "I2C Slave address is not valid!\n");
          return 1;
  preamble.buffer[0] = slaveAddr & 0xFE;  /* Slave address: Write operation */
  preamble.buffer[2] = slaveAddr;      /* Slave address: Read operation */
  preamble.ctrlMask = 0x0003;  // After the second byte,need to restart the I2C communication
  apiRetStatus = CyU3PI2cReceiveBytes(&preamble, buf, 2, 0);
  SensorI2CAccessDelay (apiRetStatus);
  return apiRetStatus;
uint8_t
SensorI2cBusTest (void)
    uint8_t buf[2];
    CyU3PDebugPrint(4," I am in Sensor I2C bus Test API222222\r\n");
    if (SensorRead2B (0x91, 0x00, buf) == CY_U3P_SUCCESS)
        CyU3PDebugPrint(4,"Buf[0] = %x Buf[1] = %x \r\n", buf[0], buf[1]);
    else
    CyU3PDebugPrint(4,"Sensor Read Failed\r\n");
    return 1;
Then I used this command:
The UART reading:
Yellow: SCLK
Purple: Sdata
