I am working in developing a FPGA based embedded system for data porting using USB 3.0 and I am using CYUSB3 KIT-003 for it. As I am not using any FMC interconnect board as I am using Mimas V2 Spartan 6 FPGA for it , I need guidance to interface these 2 boards implementing a Asynchronus FIFO .
I understand that you want to interface Mimas V2 Spartan 6 DVK to FX3 (CYUSB3KIT-003).
- Kindly check the power supply domain is the same for the pins that are connected to FPGA
- You can check the FMC interconnect board files for more details
FMC Interconnect Board for FX3™ - KBA92234 - Infineon Developer Community
- For the FX3 firmware, you can refer to the FX3 SDK for the asynchronous slavefifo firmware
Please let me know if you have more queries here
Rashi
Rashi
