Hi All,
We are using CX3 as our MIPI to USB3.0 bridge solution. We are running into issues where some of the boards initially report an error from the MIPI side.
Errors are as per below
mdlErrCnt : Multi-Data Lane Sync Byte Error Count
eidErrCnt : Unsupported Packet ID Error Count
recrErrCnt : Recoverable Packet Header Error Count
Please find MIPI to CX3 schematics
[EDIT] : Also attaching log from tera-term and firmware debug firmware for reference.
#ifdef PRINT_FRAME_INFO
if (Printflag == 1)
/*For video streaming application of higher FPS refrain from using this debug print or try to reduce the print information*/
char str[100];
int pos = 0;
sprintf(str,"\n\rProd = %d Cons = %d Prtl_Sz = %d Frm_Cnt = %d Frm_Sz = %l B", TxCountflag, RxCountflag, PartialBufSize, FrameCount, ((TxCountflag*CX3_UVC_DATA_BUF_SIZE)+PartialBufSize));
print(str);
Printflag = 0;
if (fpsflag == 1)
fps = 30000/(time1 -time0); //FPS calculate using time difference for 30 frames
print("\n\rTimeDiff = %d ms FPS = %d", (time1 -time0), fps);
fpsflag = 0;
/* Uncomment the code below to check for MIPI errors per frame*/
#ifndef FX3_STREAMING
CyU3PMipicsiGetErrors( CyTrue, &errCnts);
char str1[200];
sprintf(str1,"\n\r%d %d %d %d %d %d %d %d %d",errCnts.crcErrCnt,errCnts.ctlErrCnt, errCnts.eidErrCnt, errCnts.frmErrCnt, errCnts.mdlErrCnt, errCnts.recSyncErrCnt, errCnts.recrErrCnt, errCnts.unrSyncErrCnt, errCnts.unrcErrCnt );
print(str1);
#endif
What could be the route cause behind these errors?
Is there any workaround?
I forgot to mention that we have been able to fix this issue by connecting the 330pF capacitor instead of 10pF on C94.
From the description, I understand the issue is seen only on some of the CX3 boards' other boards are working fine (without MIPI errors). Is my understanding correct?
If yes, please refer to this KBA MIPI-CSI Protocol and Physical Layer Errors in CX3... - Infineon Developer Community to understand the cause of the errors.
Please confirm if MIPI lane routing is as per this KBA CX3 Hardware: Frequently Asked Questions - KBA9129... - Infineon Developer Community
EZ-USB™ CX3 troubleshooting guide - KBA233853 - Infineon Developer Community
Please confirm if you are using MIPI sensor compliant to MIPI CSI-2 (Version 1.01, Revision 0.04 – 2nd April
2009)
Rashi
Yes, your understanding is correct.
Yes, MIPI routing is done as per AN70707.
Regarding the MIPI sensor being compliant with MIPI CSI-2, I will check with FEA and update you.
I have tried answer#13 from KBA9129 but the issue still persists.
Can you please share if I can monitor any TPs and that can give us further insight into this issue?
Regards Jayesh
We have TPs for VSYNC, HSYNC, and PCLK as mentioned in Q10 of this KBA CX3 Hardware: Frequently Asked Questions - KBA9129... - Infineon Developer Community
Please let me know the the failure rate for this issue. Also, please share the CX3 MIPI Configuration tool settings snippet for us to check
Rashi
MIPI configurations are OK. We validated this while back. Please refer to the following post.
Back then we fixed it by connecting a 10pF capacitor on MIPI_D0_N. So in the newer design, we placed 10pF on MIPI_D0_N. But still, we are running into issues.
