Hi All,
I am writing firmware for the CX3 to interface a new sensor and am running into a confounding problem. My program behaves differently when I rearrange the order of functions in my C source code. This leads me to believe I have some memory corruption issues. I found the CyU3PMemCorruptionCheck() and CyU3PBufCorruptionCheck() functions in cyu3os.h and am trying to use them in my program. But when I do, the linker complains they are not defined. In what library are they defined?
Scott
Hi Scott,
I have attached the built project folder for a default gpifToUsb firmware. Kindly check this for your reference. Also if this does not seem to work, it would be helpful if you shared your firmware with us.
AliAsgar
