I am using a CX3 Dev Kit to interface to an Omnivision OCSHA10 image sensor. I am able to get the video from the sensor, but the image are filled with Green color. The OCSHA10 support RAW with 10 bits per pixel configuration. The CX3 is configured with CY_U3P_CSI_DF_RAW10.
Can anyone tell me why the image is filled with Green? I have attached a picture of it. My fingers can be faintly seen.
I have attached a video as well.
Thanks and Regards,
Subramanyan
Hi Subramanyan,
Windows UVC driver does not support RAW10 video format. Hence, in the CX3 firmware we are setting the GUID of the UVC descriptor file as YUY2. Eventhough the camera is outputting the video in RAW10 format, the host is interpreting it as YUY2 format. Hence, you see the greenish video.
AliAsgar
Hi Subramanyan,
AliAsgar
Hi AliAsgar,
Thanks for the quick response. How do we get around this issue?
Thanks and Regards,
Subbu
Hi Subbu,
The video data being sent to the host PC is in RAW10 format. You could use a host application that has the capability to view a video in RAW format to eliminate the greenish tint.
AliAsgar
Hi Aliasgar,
I checked this link. This talks about RAW10 format. Is this valid for CX3 Development Kit and firmware?
Please let me know.
Thanks and Regards,
Subbu
Hi Subbu,
The given KBA link is valid for CX3 Development kit and firmware.
AliAsgar
