Hello dears,
I would like to implement this example [https://www.cypress.com/documentation/application-notes/an75779-how-implement-image-sensor-interface... on my PCB, on my PCB there is CYUSB306X, and DS90UB960 deserializer with Omnivision camera Ox03A10, where could I make the necessary settings to take a picture/video like this example? thank you
AN75779 demonstrates the usage of GPIF parallel interface to connect to Image sensor. But CYUSB306X does not have parallel interface instead has MIPI CSI-2 interface.
To achieve streaming using CYUSB306X please refer to AN90369
For CX3 example firmware you can refer to EZ-USB FX3 SDK\1.3\firmware\cx3_examples
(FYI: FX3 SDK can be downloaded here)
