VlKh_2251656
I can not understand GPIFII…
Please help.
If it is possible, tell by stages how to make a simple test project. For example, there for  a timer interrupt. Each timer interrupt we reads 8 pins through a GPIFII and sore its in user memory.
Than we Invert this value in the program code and then also through GPIFII we out these 8 bits on the pins.
How to configure GPIFII without using templates?
How to make a state GPIFII machine?
How to compile this states?
How to create an h-file?
How to connect it h-file to your project&
I think that this information will be useful not only to me, but also to many other people who use your products (FX3).
Yes, I read your documents, in particular about “slave fifo”, but there is not much information specifically on the issues that I asked now.
Many, many questions...
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Hello Vladimir,
Please refer to the gpif2_designer_userguide.pdf file that comes with the FX3 SDK. The file can be found at the below path after the installation of SDK.
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\GPIFII_Designer
Please feel free to post further queries in case you have.
Srinath S
SrinathS_16
Hello Vladimir,
Srinath S
Thank you very much!
I will read this
But I'm sure there will be a lot of questions...
VlKh_2251656
I'trying complete GPIFII project
sample project
But I not understand what is Register,
what is Thread 0? (and 1,2,3)
How read from GPIF data pins to my registers?
GPIF project is compiled succefully
.h - file has been added to my project
