I'm using the UsbSpiDmaMode example to test on SPI flash, I have gone through the code, and for writing and reading the limit for the length I found is, the length should be multiple of 256 and less than 4096, but what I'm trying to do is, I'm trying to write/read 250KB at once, but while doing this I got this error:
CONTROL IN transfer
CONTROL IN transfer failed with Error Code:997
how can I write 250KB data at once to SPI flash in the Denebola kit?
In a single SPI read/write operation, 27136 bytes (0x6A00) can be read/written.
This is a limitation from the Flash side.
Could you let us know why such high amounts of data are to be written to the Flash?
AliAsgar
Hello Subhash,
Please confirm if you are aware of "Program > FX3 > SPI FLASH" in the control center to program the completer firmware to SPI Flash.
If yes, kindly refer to the source of the Control Center application and USBFlashProg (path : C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\basic_examples\) example from SDK which is used by control center to read/write to SPI FLASH
Rashi
I used example what you have referred, but even by reading 40KB I'm getting error.
Hi Subash,
Is the below error seen, when writing to flash or reading from flash?
"CONTROL IN transfer
CONTROL IN transfer failed with Error Code:997"
Please send the screenshot of the control center when the error is seen.
Are you able to read/write 256 bytes of data from/to the flash?
AliAsgar
Hi Subhash,
Is your problem solved?
AliAsgar
Solved means I'm just able to write 256 bytes to 4096 bytes smoothly but unable to read 40K bytes at once.
Hi Subhash,
Could you share with us your firmware project?
AliAsgar
@AliAsgar I did not modified anything, I just imported the code from firmware examples, spidmamode example.
AliAsgar
