we are using fx3 device(cyusb3035) with jtag segger.we are able to use jtag segger with fx3 but we need to program spi flash that is connected to fx3 device through jtag segger?how can i achieve this?
thank you
geetha.
Hi Geetha,
To program the SPI flash first of all SPI read/write firmware has to be loaded on to the FX3 chip which will program the external SPI flash. It is not possible to do it via JTAG. JTAG is mainly provided for debugging purposes.
Thanks & Regards
Abhinav
Hi Geetha,
Thanks & Regards
Abhinav
