How to use Watchdog timer
Hi everyone,
can you explain me how to use the watchdog timer. I know that the FX3 has a watchdog timer but I can't find a desciption how to use it.
Thanks for helping
Viktor
RoKl_290166
Level 4
Level 4
Welcome!
on page 27 of the latest FX3APIGuide.pdf you can find the according informations and API's for using the watchdog.
Regards!
Thanks for your response,
it works. The watchdog resets the device when it is not responsive. Now I have another problem. Where can I read out if a watchdog reset occured. I tried to read this information from register CY_U3P_PIB_PP_INIT but it is always 0x0C01 even if a watchdog reset occured.
Thanks for helping
You will have implement your own mechanism to detect watchdog reset. This can be done by using uninitialized global flag or by storing a flag in SPI/I2C EEPROM.
OK, it works.
