DiDi_4439146
First solution authored 10 sign-ins 10 replies posted
Any tips how how to shrink down the size of the images made from the ez usb suite? This is particularly useful when using fail safe boot mode which will only allow approximately 118k bytes per image on a 2mB EEPROM.
Thanks!
You can refer to this web link http://blog.atollic.com/the-ultimate-guide-to-reducing-code-size-with-gnu-gcc-for-arm-cortex-m
You can enable the Link Time Optimization by checking the last box in the Settings >Tool settings> Optimization.
Rashi
Rashi
Rashi_Vatsa
Please let me know what is the image size and how much to be reduced.
You can try building the firmware in release mode and let me know if it helps
Rashi
Rashi
max size is about 119,000 bytes and I'm pretty close to that, so basically any amount of shrinking is good... looking for the easiest ways first - already building release
You can increase the optimization level
Path: Properties>C/C++ Build>Settings>Optimization
As shown in the figure, you will have different.
Every time you change the optimization level, please check the functionality of the firmware doesn't change.
Also, let me know which compiler are you using. Is is the ARM GCC compiler?
Rashi
Rashi
Yes, ARM GCC. Also I am already using -O3, any other tips?
Rashi
Rashi
