When I use cyfxuartlpregmode.c to test UART send and receive, I found if I do not use "CyU3PUartSetTimeout (1, 50000);" :
1. the SuperSpeed Explorer Kit still works but slower (ok to me)
2. the program should send "VRS" and receive "20181114" about two times a second, but sometimes, it loses "1114" (about 200 - 3000 times, it will happen once)
So, my question is, why did this happen? and more importantly, how to choose the readLoopCnt and writeLoopCnt value?
uartConfig.baudRate = CY_U3P_UART_BAUDRATE_9600;
uartConfig.isDma = CyFalse;
io_cfg.isDQ32Bit = CyTrue;
io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT;
You can refer to the FX3 API guide in the FX3 SDK, to understand the working of this API. We suggest keeping the timeout value low.
Rashi
