When I use cyfxuartlpregmode.c to test UART send and receive, I found if I do not use "CyU3PUartSetTimeout (1, 50000);" :
1. the SuperSpeed Explorer Kit still works but slower (ok to me)
2. the program should send "VRS" and receive "20181114" about two times a second, but sometimes, it loses "1114" (about 200 - 3000 times, it will happen once)
So, my question is, why did this happen? and more importantly, how to choose the readLoopCnt and writeLoopCnt value?
uartConfig.baudRate = CY_U3P_UART_BAUDRATE_9600;
uartConfig.isDma = CyFalse;
io_cfg.isDQ32Bit = CyTrue;
io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT;
You can refer to the FX3 API guide in the FX3 SDK, to understand the working of this API. We suggest keeping the timeout value low.
Rashi
Please refer to this thread Solved: Re: FX3 UART Problems - Infineon Developer Community with similar issue
Rashi
Hi, Thanks for the reply, I found that topic before. What I really want to know is:
there are lots of values between 1 , 50000, 0xFFFFFFFF for both read and write param, and the read and write process is really a small part of the whole project
So I'd like to know more detail about how to pick a "right" value to avoid any other potential problems
Is there any document I can read?
Rashi
