Hi, dear friends,
I met a problem in FX3 to receive residual data in FX3:in order to achieve high speed, I set a large transfer data length for XferData() function, such as 1024*1024, but at the end of the data transfer, there will be a little amount of data smaller than 1024*1024.So when XferData() time out,I can't receive the data tail .
In addition,I want to know how many bytes in the endpoint buffer before XferData ? so I can set Xferdata second parameter with this.
here is part of my code:
BYTE * pContext=NULL;
long nBulkLen = 1024*1024;
pContext=pBulkEpIn->BeginDataXfer(pBulkBuf, nBulkLen, &oRdOvLap);
if(!pBulkEpIn->WaitForXfer(&oRdOvLap, 1000))
pBulkEpIn->Abort();
WaitForSingleObject(oRdOvLap.hEvent,INFINITE);
nRetCode=0x01;
TRACE("time out!\n");
//break;
bool recvRet = pBulkEpIn->FinishDataXfer(pBulkBuf, nBulkLen, &oRdOvLap, pContext);
//bool recvRet = pBulkEpIn->XferData(pBulkBuf,nBulkLen);
TRACE("the actual receive length = %d ,recvRet = %d\n",nBulkLen,recvRet);
Does anybody know how to solve this problem?Thank you very much and best wishes.
Can you please confirm if the residual amount of data was actually committed by Fx3? (available for transfer to the USB Consumer).
Please check if you are able to receive this residue using Cypress Control center or streamer. If so, please check your FX3 firmware.
regards,
- Madhu Sudhan
