I'm using the Denebola kit, and I want to implement a failsafe firmware update, so for that, I need to modify a code to get vendor request from the Firmware update app, which provided in https://community.infineon.com/t5/Resource-Library/FX3-Fail-Safe-Firmware-Update/ta-p/246074
Actually I added event to get vendor request, but even adding evnet using
ret = CyU3PEventCreate (&glBulkLpEvent);
and tried get event with this
stat = CyU3PEventGet (&glBulkLpEvent, eventMask, CYU3P_EVENT_OR_CLEAR, &eventStat, 10);
but I'm unable to get event.
what is the way get vendor commands?
Please find the attached descriptor file with added vendor interface. Please track the changes using macro VENDOR.
Kindly, do appropriate changes for HS and FS descriptors also
Rashi
Please let me know if you have added vendor interface to receive the vendor commands.
If yes, you can refer to USBBulkSrcsink application, to understand handling of vendor requests in firmware. Also, confirm if the request sent by USB host is received properly by the device.
IF you don't want to add vendor interface to OV5640 firmware, please refer to this KBA FX3/CX3: UVC Extension Unit Application – KBA23046... - Infineon Developer Community
Rashi
Nope, I did not added any vendor interface
If you want handle vendor commands, you would need vendor interface i.e. UVC+vendor. You can refer to AN75779 firmware to add vendor interface to UVC by enabling macro #DEBUG_ENABLE. Please note AN75779 is for FX3but you can refer to the firmware to add vendor interface to CX3 firmware
If you do not want to add vendor interface, you can use extension unit (KBA shared) of UVC interface to send/receive vendor define data
Rashi
I want to use Firmware update app which was provided in FailsafeFirmware update,
for that which one do I need to follow? vendor interface or KBA?
Hello Rashi vatsa, I tried to follow this,
but still unable to send vendor specific commands
Can you please share your firmware for us to check?
We would only need the fx3 firmware files (sensor settings are not needed)
Rashi
Thanks Rashi I replaced descriptor files with what you have given,
I got one problem it's driver is not installed, where I can find driver for this
Please let me know if the device is plugged in as USB 3.0 or USB 2.0 device.
I had only modified USB 3.0 descriptors and it works fine at my end. One interface will come under Camera section of device manager (CX3- UVC) and another will come under other devices (with yellow mark). The interface in other device should be binded to cyusb3 driver as it a vendor interface.
Please refer to point A of this KBA Trouble Shooting Guide for the FX3/FX3S/CX3 Enumer... - Infineon Developer Community to bind the driver
Rashi
Thanks Rashi, I will look on it
