Can I run USBBulksourceSink and OV5640 example simultaneously in Denebolakit?
Please find the attached firmware project.
In the device manager, CX3-UVC comes under Camera Section and "Regami-UVC" under Other devices. Please bind "Regami-UVC" to the driver attached with this reply.
Password for the driver package: infineon
AliAsgar
USBBulkSourceSink and OV5640 example can be added in a single CX3 firmware. But running video streaming as well as bulk transfer simultaneously may result in Bandwidth issues.
I assume the descriptors file with UVC+vendor interface has already been shared by one of our engineers with you.
For the uvc.c file, create a MANUAL IN and MANUAL OUT channels between CPU and USB. Register a callback function for it. Implement the code for the callback function and BULK transfers as per the USBBulkSrcSink firmware example in the FX3 SDK.
AliAsgar
I merged it perfectly, but still only OV5640 is working not bulksourcesink
Could you share your firmware project with us?
AliAsgar
AliAsgar
