doch_3739346
Level 4
Level 4
By referencing SRAMMaster example, I've created a simple register read/write project.
Please note, I've swapped write initial state name (START) with read initial state (RD_START), since don't know how to start the read flow.
Like the example, I'm using AddressCounter as address source.
It's "working", but start address is tied to 0.
How can I set start address to any 32 bits value?
alamandaa_16
10 likes received First like received
Hello Dong Chen,
--CyU3PGpifInitAddrCounter funtion is used in the firmware to configure the GPIF LD_ADDR_COUNT with the desired initial value, limit and counting mode.
This API should be called after GPIFLoad and before GPIFStart in the Firmware.
example : if you want to set start address to 10 and address limit to 255, you should set the initial value,limit and incerement value using following API.
void CyU3PGpifInitAddrCounter ( uint32_t initValue, uint32_t limit, CyBool_t reload, CyBool_t upCount, uint8_t increment )
                   uint32_t initValue  = 0x0000000A
                   uint32_t limit         = 0x000000FF
                   CyBool_t reload    = CyTrue
                   CyBool_t upCount = CyTrue
                  uint8_t increment   = 0x01
Anil Srinivas.
