In my case, I need synchronous mode to receive data, while the waiting time before data is uncertain. So I configured the timeout to Infinite. But I found that when I needed to stop, there seemed to be no way to stop.
Hi Instead of setting the timeout to infinite, please call the XferData at regular intervals again and again with finite timeout
Of course, I tried.
The test found that the data could not be received when the next transmission was started after a timeout.
For example, set timeout to 5 seconds, and the data comes at the sixth seconds, then I could not get the data at all.
Do you have any ideas?
Chad
Please refer to the control center and streamer source code to and handle the transfer error, the same way it is implemented in our examples.
-Madhu Sudhan
Hi Madhu,
Thanks,I had solved it。
Chad
