I want to customize the USB device name. For example, when download the firmware into FX3, it will be shown as "Cypress USB StreamerExample" in control center, can I know how to customize this name in the firmware code?
Zoe
You need to edit the name in the cyusb3.inf file "C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\driver\bin". When you manually bind the device to the modified driver file again, you cna notice the name change.
But after doing that the driver loses its certification. You need to get it signed again.
-Madhu Sudhan
