EvEv_2610591
I have Olimex ARM-USB-OCD-H debuger and I want to debug FX3 device placed on my DevBoard.
I use Cypress EZ USB Suite.
I installed OpenOCD 0.6.1 as in the example (12.2.1.2 FX3 Programmers manual) and created ezusb_fx3.cfg file.
I installed drivers for Olimex ARM-USB-OCD-H using Zadig 2.4.exe.
# Olimex ARM-USB-OCD-H
# http://www.olimex.com/dev/arm-usb-ocd.html
#interface
interface ft2232
ft2232_device_desc "Olimex OpenOCD JTAG ARM-USB-OCD-H"
ft2232_layout olimex-jtag
ft2232_vid_pid 0x15ba 0x002b
# Target: CYPRESS FX3 ARM926-ejs
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME fx3
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
if { [info exists CPUTAPID] } {
set _CPUTAPID $CPUTAPID
} else {
set _CPUTAPID 0x07926069
#delays on reset lines
jtag_nsrst_delay 200
jtag_ntrst_delay 200
jtag_khz 1000
jtag_khz 1000
reset_config trst_and_srst srst_pulls_trst
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
jtag_rclk 3
# Target configuration
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME arm926ejs -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm926ejs
jtag_khz 1000
When I tried to connect debuger to the FX3 I see next message:
Open On-Chip Debugger 0.6.1 (2012-10-07-10:39)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
DEPRECATED! use 'adapter_nsrst_delay' not 'jtag_nsrst_delay'
adapter_nsrst_delay: 200
jtag_ntrst_delay: 200
DEPRECATED! use 'adapter_khz' not 'jtag_khz'
adapter speed: 1000 kHz
trst_and_srst srst_pulls_trst srst_gates_jtag trst_push_pull srst_open_drain
RCLK - adaptive
Error: libusb_open() failed with -12
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: fx3.cpu: IR capture error; saw 0x0f not 0x01
Warn : Bypassing JTAG setup events due to errors
Info : Embedded ICE version 15
Error: unknown EmbeddedICE version (comms ctrl: 0xffffffff)
Info : fx3.cpu: hardware has 2 breakpoint/watchpoint units
Warn : WARNING: unknown debug reason: 0xf
Warn : ThumbEE -- incomplete support
I sink that driver for ARM-USB-OCD-H wasn`t opened (Error: libusb_open() failed with -12).
I tried to use OpenOCD 0.9.0 from Olimex packet for debuger. I this case with the same ezusb_fx3.cfg file I have seen message:
Open On-Chip Debugger 0.9.0-rc1 (2015-04-24-22:09)
http://openocd.org/doc/doxygen/bugs.html
trst_and_srst srst_pulls_trst srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
RCLK - adaptive
embedded:startup.tcl:21: Error: Unknown param: -variant, try one of: -type, -event, -work-area-virt, -work-area-phys, -work-area-size, -work-area-backup, -endian, -coreid, -chain-position, -dbgbase, or -rtos
in procedure 'script'
at file "embedded:startup.tcl", line 60
in procedure 'target' called at file "ezusb_fx3.cfg", line 44
in procedure 'ocd_bouncer'
at file "embedded:startup.tcl", line 21
Than I have modifyed ezusb_fx3.cfg file as at the file openocd-0.9.0-rc1\scripts\interface\ftdi\olimex-arm-usb-ocd-h.cfg:
#interface
interface ftdi
ftdi_device_desc "Olimex OpenOCD JTAG ARM-USB-OCD-H"
ftdi_vid_pid 0x15ba 0x002b
ftdi_layout_init 0x0908 0x0b1b
ftdi_layout_signal nSRST -oe 0x0200
ftdi_layout_signal nTRST -data 0x0100
ftdi_layout_signal LED -data 0x0800
} else {
set _CHIPNAME fx3
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
} else {
jtag_khz 1000
jtag_khz 1000
jtag_rclk 3
jtag_khz 1000
And recieved message:
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
RCLK - adaptive
in procedure 'target' called at file "ezusb_fx3.cfg", line 53
How to fix this problem and begin debug DevBoard?
Hello Evgen,
Please go through the following attached folder which contain configuration file.
Anil Srinivas.
alamandaa_16
10 likes received First like received
Hello Evgen,
-Please refer to following document which speaks about Debug an FX3 firmware with help of ARM-USB-OCD-H JTAG adapter and open OCD GDB Debugger.
Anil Srinivas.
I have installed driver from OpenOCD 4.0  for Channel A (ref. to the document). And now I see next message:
RCLK - adaptive
Info : max TCK change to: 30000 kHz
Info : JTAG tap: fx3.cpu tap/device found: 0x07926069 (mfg: 0x034, part: 0x7926, ver: 0x0)
Info : Embedded ICE version 6
target state: halted
target halted in ThumbEE state due to debug-request, current mode: System
cpsr: 0xffffffff pc: 0xfffffff9
MMU: enabled, D-Cache: enabled, I-Cache: enabled
ARM-USB-OCD_H connected with FX3, but can`t work in debug mode. How can I fix it?
Hello Evgen,
Anil Srinivas.
I'm trying to get this working also.  The olimex.zip appears to be password protected.  Please can you send me the password?
Please find the folder attached without the password protection.
AliAsgar
