Nolan_Maverick
10 sign-ins First like given 5 sign-ins
       I'm trying to downgrade MIPI lanes from 4 to 2 in MIPI CSI controller, for that first I changed the sensors output MIPI lanes to 2, but still MIPI CSI controller configuration is 4, it streamed fine,
then I changed MIPI CSI lanes to 2, so now both sensor and MIPI CSI controller has 2 lanes, now it is not streaming, I believe that its problem with  configurations of MIPI CSI controller, How to configure MIPI CSI now?
Bakal
50 sign-ins 10 solutions authored 25 replies posted
The transmitter configuration (sensor) and the receiver configuration (controller) should be the same. Set the configurations in the MIPI configuration tool -> Image Sensor Configuration Tab and use the generated configuration.
Sakshi Bakal.
Bakal
Sakshi Bakal.
