Can anyone tell me how to add Descriptors of USBBulkSourceSink example to OV5640 example, to support vendor specific commands sent by Firmware updater provided in failsafe firmware update?
Please refer to the following KBA:
https://community.infineon.com/t5/Knowledge-Base-Articles/Vendor-Interface-in-UVC-KBA218335/ta-p/247...
You can use this as a reference to add a vendor interface to OV5640 firmware.
Jayakrishna
Jayakrishna
I followed the same procedure and then I'm able to get one interface, as shown below
It is enumerated as USB Serial Port COM17, but how to modify descriptors as it should communicate with Firmware Updater app
Please refer to the response in this thread How to modify OV5640 code to get vendor specific c... - Infineon Developer Community
Rashi
@JayakrishnaT_76 I found this thread https://community.infineon.com/t5/USB-superspeed-peripherals/CX3-Update-firmware-in-SPI-flash-over-H...
useful but compiling HID_sample.c I'm getting
HID_Sample_App.c:9:20: fatal error: hidsdi.h: No such file or directory
can you share required files to compile perfectly?
I tried compiling the host application the thread at my end and it compiles successfully.
Please check if you have installed the required components from visual studio
Rashi
@Rashi_Vatsa @JayakrishnaT_76 , I connected my Denenbola kit to USB2.0
and I even changed to connect to host as USB2.0 with CyU3PConnectState(CyTrue, CyFalse)
I'm able to stream video, but whilee flashing new firmware with
HID_Sample.exe <Image_name.img>
I get this
Debug>HID_Sample_App.exe Cx3UvcOV5640_BASIC.img
.................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................first setoutput report failed
As this query is different than the main thread description, we would request you to create a new thread for this query. This will be helpful to other community members as well.
Or Please refer to this thread Solved: Unable to get Images when I try to use "Update fir... - Infineon Developer Community
Rashi
