Hi Cypress,
I want to transfer the data from PC to fx3 by UVC bulk-out, fx3 if supports this function or not, if yes, how do I modify UVC descriptor ?
- Please explain your application requirement as to how the data is being transferred from the host to the FX3? Is it through a standard UVC application or is it through a custom application?
- Is it mandatory that you need UVC based application for your application?
- FX3 supports BULK-OUT transfer. Please refer to the AN65974 firmware for details on FX3-FPGA transfer.
Srinath S
Srinath S
