We are trying to embed CyAPI.lib in a Qt project and get these errors when trying to link:
Some questions:
We also have a source code version of the CyAPI.lib, that we have added to our Qt project.
But the source code doesn’t match the CyAPI.lib that we have, and has an error that we have difficulties to work around.
When using the CyAPI.lib in a VS project, we don’t have the error (this way we conclude that source code and CyAPI.lib don’t match).
Yes, CyAPI.lib is compiled with Visual Studios. We have not tested using CyAPI.lib in QT applications.
Have you linked the CyAPI.lib in your project and included all other dependencies?
The latest source of CyAPI.lib is present in FX3 SDK.
Please download CyUSB3_USB_Suite_Souce.zip file from this link : https://www.cypress.com/documentation/software-and-drivers/ez-usb-fx3-software-development-kit
Both the library and its source is present in the zip folder.
library path: <installation directory>\Cypress\EZ-USB FX3 SDK\CyUSB3_USB_Suite_Source\CyAPI_Library_Source\CyAPI\library\cpp\lib\<architecture>
If you are using the latest source, then please check all the properties of the project.
Yatheesh
