Hello
    we need 8-bit GPIF Configuration Data for Slave FIFO Sync.use 8  bit interface
          How to configure?
 Best regards.
The GPIF II designer has the option of configuring the interface for 8-bit mode (I'll post an update here once the version with support for this is released). Other than that the rest should be just the same as configuring for 16-bit mode.
Anand
