hello, please help me, when I wanted to load a program in RAM I accidentally pressed on I2C EEPROM and after that the 2 LEDs lit on the other side of the board and since then nothing appears in the Control Center, What to happened? did I brock the pcb ?thank you
Help
Thank you, the problems was with my USB connection, my laptop didn't recognize the pcb.
Could you please answer following questions.
1. Does resetting the device or disconnection and reconnection of the device from host bring back the device as bootloader device?
2. Which kit is being used or is it a custom board?
3. Are the PMODE pins set to Z11?
4. Which pins of the PCB are the LEDs connected to?
5. Could you elaborate on the exact procedure which you had performed?
AliAsgar
