PoVe_3939176
5 likes given First like given
What type of SDK file and debugger need to be used for debugging the code as one Serial JTAG is been used in CYUSB3343 ?
Kindly please let us know.
Sananya_14
Please explain what code you want to debug for HX3C? There is no SDK support for the part, and the PD configuration is fixed. You can however change the configuration of the hub using the GUI based tool Blaster Plus.
Sananya
Sananya_14
Sananya
