OlEr_1999891
50 replies posted 25 replies posted 25 sign-ins
Hi!
We are making an updated design of our USB hub solution were we are considering HX3. One customer requirements is that it should support USB Asynchronous audio streaming for their high-end audio solutions. However, we are unsure if that has any dependency on the hub-part of the solution or if it is only a matter for the host and USB-device side? Anything to consider regarding the clock (or similar) for the HX3 and hub?
Cheers
Olof
YiZ_31
Hi Olof,
HX3 is a standard USB hub that meet the USB-IF specification. The only thing you need to consider is that whether the bandwith of the upstream port(USB 3.0 5Gbps) can meet your requirement.
Eddie
YiZ_31
Hi Olof,
Eddie
