HOW TO USE THE CYPD3121 TO DESIGN A TYPEC POWERBANK ?
HI,i am designing a type c  power bank used cypress chip cypd 3121,and I have some question , could you give me some guidance  or suggestions ?
1. about the software " EZ -PD Configuration Utility " :i want to create a new firmware for the power bank , there are  just active cable 、 display port  、  notebook 、  monitor 、 power  adapter , but i don't find the power bank item .just like the picture 1, so which one should i choose for power bank ?
2. about the software " PSoC Creator 3.3 ": the similar problem ,in the code example , there is no cypd 3121 power bank code example , just like the picture 2 ,so which one should i choose for  cypd 3121 power bank ?
3.could you give  me some design examples files or some helpful webs ?
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Suggest you to contact the place where you get the chip cypd 3121, or one of the distributor:
http://www.cypress.com/cypress-franchised-distributors
Roy Liu
Roy_Liu
Roy Liu
