Hello
For LED control, I am thinking of controlling GPIO High/LOW with FW. However, I would like to synchronize the GPIO High/LOW switching with the Frame signal of the image sensor, but is it possible to control the GPIO by synchronizing it with the "Frame signal" with the CX3 F/W?
If possible, how do we specifically sensor Frame singnal synchronize with the CX3 F/W?
Best Regards
USB Superspeed Peripherals
You can try asserting the GPIO in the DMA callback when the first buffer of the frame is received and de-assert when the DMA buffer with partial buffer is received.
To make the transition faster, you can try this using GPIO register directly.
Please note that this won't give you exact synchronization with the FV and LV due to the delay/processing in DMA callback
Rashi
Can you please elaborate on why you need to control the GPIO based on the Frame signal? Also, by Frame signal, do you mean Frame valid signal? And do you want it to be perfectly synchronized with the FV signal?
Jayakrishna
Rashi
