dimac_335226
Hi there,
I am using GPIF interface on FX3 chip in a serial mode, where only two data pins are involved (DQ14 and DQ15)
I would like to know is there a way to define state (high or low) of the output pin when I receive data on the input pin?
By default, when I am in the state to receive data, the output pin is held at 0. How can I make it to be 1 for the duration of the read cycle?
Many thanks,
Dima
I am afraid, such a feature is not possible.
- Madhu Sudhan
- Madhu Sudhan
