Question to the State Machine from the GPIF II Designer.
is there a possibility to switch a state after a spezified time?. Something like, if you in State1 longer then 5 Seconds, goto state 2
kind regards
Matthias Macho
Hello Matthias Macho,
You can use the LD_DATA_COUNT and 'Repeat' action of the GPIF II designer to implement this.
- The 'Repeat action until next transaction' check box in the state properties can be used to repeat the actions in the particular state for 'Repeat Count' clock cycles.
- The DATA_CNT_HIT parameter will indicate that the counter value is hit.
- LD_DATA_COUNT loads the data counter with the value corresponding to the delay required in the state.
Srinath S
Srinath S
