MaMa_4034336
Hallo,
my question is, is it possible to put a Header in incoming Data in GPIF II State machine or do i have to it like the UVC example in the firmware.
My situation. I'm getting 10Bit Data from an Image Sensor. Since the GPFI II only can read 16Bit, i have 6 Bit free. Every time a new line occur, i want to count up a counter an write the value in the 6Bit i don't use.
kind regards,
Matthias
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Hello Matthias,
The data cannot be modified from the GPIF II state machine. The firmware has to take control in order to modify the data. As you have mentioned, it can be done in the way UVC example has implemented it.
Srinath S
SrinathS_16
Hello Matthias,
Srinath S
