Jan 18, 2017
02:44 PM
Jan 18, 2017
02:44 PM
FX3 datasheet contains GPIF II timing diagram for asynchronous DDR mode. However, there is no any additional information about how to use this mode. It is also unclear how to configure this mode in GPIF II Designer.
The API has only one thing that has relation to DDR -- DDR_MODE flag in GPIF_CONFIG register. Documentation says DDR_MODE flag "Select 2X clock as the core clock". That's all.
My guess is that setting DDR_MODE and DLE_PRESENT will allow for latching of DQ lines on every (both rising and falling) edge of CTL[1].
Is my understanding correct? Could you please clarify.
Thank you.
