N_N
5 sign-ins First solution authored First reply posted
Hi! On my board I have a 32-bit parallel FPGA configuration interface connected to the FX3 chip. In order to use it I need to implement a synchronous master FIFO interface, I guess. The problem is that I can't make a GPIF configuration using GPIF Designer (ver 1.0) I downloaded recently. The GUI simply doesn't provide necessary options and it's different from what is presented in AN87216 (Designing a GPIF™ II Master Interface).
For example, here is the screenshot from the AN:
And here is what I have:
There are a lot less options to select and, in particular ,there is even no 'master' option I need.
Yes, It's possible to create .h file manually, but maybe there is a possibility to get that version of the GPIF Designer from the AN?
N_N
 I've just realized that I need to create a new blank project to get all those extra options.
N_N
Ajeethkumar
250 sign-ins 50 solutions authored 10 likes received
It's good to hear that your issue is resolved.
Ajeeth
