GPIF 2 Designer
leda_289486
10 sign-ins 5 sign-ins 100 replies posted
where can the software "GPIF II Designer" be downloaded for FX3 ?
The available GPIF designer is dated from 2003 and seems to have no support for FX3 inside ?
D.
GPIF II designer should be available in the current release of the SDK. Please check with your marketing contact to get the latest release. Please be aware however that the current GPIF II designer only allows the user to try a few pre-built interfaces and would not allow you to design your own custom interface. That would be supported in the next release.
Anand
leda_289486
I've got the release 384 of the SDK now (to benefit from elf2img program), but I cannot find the GPIF 2 designer application.
Is this the correct version of the current SDK ?
D.
Sorry. My bad.
It seems that release hasn't happened yet. I'll update you once it is done.
Anand
The release with the few prebuilt configurations is available now as a separate installable.
Anand
Have a customer asking for GPII designer for FX3. I remember from training only a few interface examples are available and that  the customer should stick with these as the GPII designer wasn't ready for prime time. Please let me know what these examples are(GPII interfaces), whay one whould use one Vs the others.. Also any update when the customer can design his own interface GPII.
Cypress Specialist at Arrow
Larry
Hi Larry,
The supported modes at this point of time are
Async ADMUX
Sync ADMUX
Async slave FIFO
sync slave FIFO
Async SRAM
Anand
