KePa_4784036
10 replies posted 5 questions asked First like received
Hi Cypress Team,
The question is about the GPIF-to-USB Performance on an AUTO DMA Channel section in the AN86947 - Optimizing USB 3.0 Throughput with EZ-USB® FX3 document.
I found it very helpful to verify the transfer throughputs results from the different configurations. However, on my end, I'm currently working with a board that has a GPIF II 16-bits data and the results from the document are from a GPIF II 32-bits.
I was wondering if I can just use the results and divide them by 2 to adapt them to my 16-bits GPIF II.
Thank you
Keven
AliAsgar
1000 replies posted 250 solutions authored 750 replies posted
Hi Keven,
Yes,  you are right. You can just divide the throughput results by 2 and adapt them to 16 bits.
I tested the throughput of the GpifToUsb firmware example provided in the FX3 SDK with both 32 bits as well as 16 bits GPIF. I have attached the snippets of the host application displaying throughput.
                                         16 bits GPIF        32 bits GPIF
AliAsgar
AliAsgar
Hi Keven,
AliAsgar
Perfect! Thank you for the confirmation 😁
