jomac_1309706
Welcome! First question asked First reply posted
After downloading my program image to EEProm via the following code
enmResult = fx3.DownloadFw(filename, FX3_FWDWNLOAD_MEDIA_TYPE.SPIFLASH);
I want to hard restart the device to force the new program to load from EEProm.   We were able to do this with the FX2, but have been unable to find how to do this under FX3.
Any help  / direction would be appreciated.
J.
ManaskantD_51
Welcome! 25 solutions authored 10 solutions authored
Hi John,
You can use the fx3.Reset() API after the DownloadFw API. But you need to make sure your PMODE pins are already set for the I2C boot.
YangyangC_06
Hi John
It is impossible to do that. You need to change PMODE settings after downloading firmware.
ManaskantD_51
Hi John,
YangyangC_06
Hi John,
My previous response is not correct. Please follows the way provided by Manaskant.
