GiSa_4520796
Level 4
Level 4
First like received
I am trying to use file system to write data into SD card(s0 port).I am using EZ USB SUITE firmware and seggar Jlink for debugging, can anyone help me to do this.
After removing SD Card from hardware i should be able to read data by inserting it in mobile.
Srujana.
YashwantK_46
100 solutions authored 50 solutions authored 50 likes received
Hi Srujana,
You can implement this application on a EZ-USB FX3S device.
Please go though the example frimware FX3SFileSystem found at path: C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\storage_examples\cyfx3s_fatfs
You can modify the firmware according to your application.
Yashwant
YashwantK_46
Hi Srujana,
Yashwant
