Hello.
First, my goal is a streamer application (uvc) which capable to stream YUV data.(According to an75779)
The sensor output is 1280*720 30fps YUY422,DVP 8 bit.
So my GPIF is 8 bits,LD_ADDR_COUNT/LD_DATA_COUNT is 16367.
Other configurations have not been changed because I think they are consistent with the sensor I am using, but the UVC output is only 15FPS at the moment.And the image is normal
Can you give me some advice?
USB Superspeed Peripherals
- uvc
1. Could you let us know the details on the frame blanking?
2. Could you share the debug prints with us?
AliAsgar
AliAsgar
I solved the problem because the rising edge of FV was not wide enough.Now my UVC can output 30fps,thanks.
